March 2, 2004, 05:58 |
FLUENT-NASTRAN ON SAILS
Hello everybody:
I´m working on sails, I have a pair genaker-main configuration, and i use fluent to get the forces on the sail. Then i get the deformation on a struct program call Nastran. My problem is that my sail have to have a young module like iron to deform a normal lenght. Does anyone knows were the problem can be?. I had use both, nonlinear and linear model to get my new deformed sail, but it doesnt work. the fluet forces seems to be right but im not sure becouse i dont have experimental data. Thanks in advance. |
March 3, 2004, 07:59 |
Re: FLUENT-NASTRAN ON SAILS
Well, I don't know much about your sail, but do you have reliable mechanical properties for it? As to the young module of iron as compared to the sail, I wouldn't be much surprised if they were close to each other.
March 4, 2004, 13:49 |
COuld you post the forces you get (with apparent winf angle too). Ill be able to check them. I agree with George about the modulus if it s built out of high tech fabric.
Nico |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
Abaqus - Fluent Coupling WITHOUT MPCCI | s.mishra | FLUENT | 1 | April 5, 2016 06:47 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
fluent to nastran | F. HUCHET | FLUENT | 1 | April 29, 2003 17:57 |
