sub-surface creation.
Old   June 4, 2004, 08:39
Default sub-surface creation.
Chris
I would like to know whether it is possible to create a sub surface (a 3D-surface out of an existing surface) for calculation purposes (eg calculate the average heat transfer coefficient for a particular zone on a surface).
Old   June 4, 2004, 13:59
Default Re: sub-surface creation.
Arun
A surface is 2D and that you can create in Fluent using Surface --> Plane in the main menu.
Arun
Old   June 5, 2004, 00:17
Chris
A surface is not necessarily 2D but can be 3D too. A 2D surface is usually called a plane.
I have a 3D surface from which I need to extract data out of part of it. Therefore I was thinking to create a sub-surface from it. Is this posssible?
Old   June 5, 2004, 20:18
Arun
Hi Chris,
You can try Tecplot where you can create sub-zones like however you want. I haven't tried it in Fluent.
Thanks Arun
Old   June 7, 2004, 03:32
Chris
Thanks Arun.
I am totally new to Techplot. Can you please give me some more information.
Chris.
Old   June 7, 2004, 12:31
Arun
Hi Chris,
Import your data into Tecplot (File --> Import). Then create a sub-zone using Data -->Create zone-->Subzone. Select your I, J and K to create the subzone. Now you can compute your required value using equations in this zone. I don't know if this could be done in Fluent itself. I think Fluent should let you do this. Do experiment the Surface menu. Good luck.
Arun
Old   June 11, 2004, 17:15
Podila
Hello Friends, This can be done in FLUENT using the option surface. In gui Surface> Isosurface so on and so forth. Let me know if u are not clear with it. Bye Podila
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
problem with surface creation in ICEM from multiple curves dialolema ANSYS Meshing & Geometry 2 October 27, 2014 13:14
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
