November 11, 2004, 08:45 |
Stirred tank reactor
I would like to simulate a stirred tank reactor with a rushton turbine using fluent and gambit. Did anyone try this before? If so, how did you do it? I generated and meshed the reactor building blocks in gambit and then assembled them using the tmerge command. I modified the grid in fluent using the separate, merge, and fuse panels but everytime I fuse face zones I get an error message saying 'SEGMENTATION VIOLATION'. Can anyone offer me a better strategy?
November 11, 2004, 09:12 |
Re: Stirred tank reactor
I work with stirred tank simulation. The first thing you have to think is that you have two zones: one moving zone (with the impeller) and a static zone (with the tank wall). I usually build the mesh of the two zones in one simple Gambit file, but take care because between these zones you have to build a interface (it means that the volumes of the moving zone must not be connected with the volumes of the static zone).
In Fluent all you have to do is unite the interfaces and define a moving scheme to the moving zone (MRF or sliding mesh). I hope it helps. galeazzo |
November 11, 2004, 10:21 |
Thanks for your advise. Can you tell me which meshing scheme you use in gambit? How do you construct the turbine and the baffles : with volumes or with faces?
November 12, 2004, 07:31 |
I usually use the map meshing scheme. I prefer to build the turbine with volumes, but just with faces still a good aproximation.
Hi! |
December 4, 2004, 20:21 |
January 23, 2011, 14:56 |
helpiouioug hgghgh fghhj ggd
#6 | |
A_A
i'm working on simulation of a batch stirred reactor by gambit&fluent you mentioned that there's good tutorial on fluentusers.com but unfortunately i can't access to this site. would you please sending the tutorial to my mail? aboozar.azarafza@gmail.com i'll be appreciated for your kindness. |
Meshing of a stirred tank reactor | Ajayi Olukayode | FLUENT | 8 | October 3, 2012 02:24 |
Stirred Tank Reactor Modelling | alice | FLUENT | 2 | January 23, 2011 14:59 |
Stirred Tank Reactor | Sanjib | FLUENT | 3 | October 18, 2010 05:42 |
Gas-liquid stirred tank reactor | bawadi | FLUENT | 0 | October 30, 2009 03:24 |
MRFsimulation stirred tank reactor | Domi | FLUENT | 2 | February 22, 2005 15:06 |
