Parallel Fluent on Linux clusters
Old   November 23, 2004, 00:06
Default Parallel Fluent on Linux clusters
Chengwang Lei
Dear Fluent users,
I am an inexperienced user of Fluent (version 6.1.22) and a new user of Linux clusters. The cluster that we have consists of 16 Pentium 4 2.66GHz processors with a 1-gigabit switch, and the OS is Debian Linux 2.4.26.
At the moment I am trying to run Fluent in parallel on the linux cluster but with no success. The fact is that when I ran a 2D test case of about 51,500 cells with 4 processors, I got about 4 times slowdown instead of speedup compared with the speed of the serial job with a single processor. The partition was done by Fluent automatically in that particular case.
I am wondering if anyone can give me some advices or point me to any sources for information with regard to running parallel Fluent processes on linux clusters.
Thanks in advance.
Chengwang
Old   November 23, 2004, 04:55
Default Re: Parallel Fluent on Linux clusters
mange
Maybe you should try a bigger test case. In your case the transfer time of data between computationalnodes is dominating over actual iteration time.
Old   November 23, 2004, 18:23
Chengwang Lei
I have tried the same case on a different platform and got about 3.8 times speedup. So probably the size of the test case is not an issue.
Old   November 24, 2004, 02:05
jyo
sir,
We are new to fluent parallel processor. But we have tried recently fluent parallel processor in windows machines. Now we want to try using linux machines. (i.e)From windows to linux machines. We have fluent in our windows system and clusters are linux m/cs. We have tried in the following way:
We have opened fluent from windows m/c using the command "fluent -serv -a". Then we use the run command from file menu and default was selected as communicator, then we clicked listen button. We have logged on to linux m/c using telnet and we have tried the following command "fluent 3d -psmpi -t2 -cx windows system ipaddress:some number:some number" We got the following messge bash:fluent:command not found
If u can help us in this regard,it will be useful for us.
Thankyou jyo
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
Fluent 12.1 on Linux x64 Architecture Issue fivos FLUENT 5 April 24, 2010 15:19
FLUENT in Linux L3munoz Hardware 4 October 29, 2009 04:58
Install Fluent in Linux L3munoz FLUENT 0 July 21, 2009 14:55
Fluent parallel poovanna FLUENT 0 March 23, 2007 23:22
