Quad Meshing Hollow Faces in Gambit
Old   February 6, 2005, 14:07
Default Quad Meshing Hollow Faces in Gambit
Shuto
Hi all,
I am trying to quad mesh a 'hollow' face - a rectangular face with a rectangular hole in it - using Gambit.
All my edges are connected, the inner corners are set to Corner and the outer ones set to Edge. I can't get Gambit to produce nice square cells with right angles between cell faces. I am using submap as map defaults to submap anyway.
How can I get square cells?
Thanks, Shuto.
Old   February 6, 2005, 17:21
Default Re: Quad Meshing Hollow Faces in Gambit
Tarnz
Use Size Function (i.e. fixed size fct, the edges of the hollow as sources, the whole face as attachment, growth rate=1) and then mesh afterwards. Hope this works.
Old   February 7, 2005, 08:57
Shuto
Thanks Tarnz,
I gave it a shot but it comes out the same. Fluent think it's a bug and have recommended splitting the face so there are no hollow bits. It works but slows things down considerably.
Can anyone think of another way around this?
Cheers, Shuto.
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Quad Meshing with gambit Cyril FLUENT 1 March 6, 2006 09:45
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
