Solid-Solid
Old   February 7, 2005, 05:00
Default Solid-Solid
Doru Grosan
Is it possible to define in Fluent two adjacent solid zones with different physical properties and to model heat transfer?
Thanks
Old   February 7, 2005, 09:56
Default Re: Solid-Solid
Doru Grosan
I found the answer. If the geometry has an internal wall that separate two solid zones (it is possible also solid-fluid or fluid-fluid) automaticaly is created a special wall and in the wall panel we can choose coupled for the conjugate heat transfer.
Solid combustion problem.... godspeedsam FLUENT 3 May 24, 2022 04:29
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 3, 2013 23:04
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 07:14
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 15:20
