February 7, 2005, 05:00 |
Solid-Solid
Is it possible to define in Fluent two adjacent solid zones with different physical properties and to model heat transfer? Thanks |
February 7, 2005, 09:56 |
Re: Solid-Solid
I found the answer. If the geometry has an internal wall that separate two solid zones (it is possible also solid-fluid or fluid-fluid) automaticaly is created a special wall and in the wall panel we can choose coupled for the conjugate heat transfer.
Solid combustion problem.... | godspeedsam | FLUENT | 3 | May 24, 2022 04:29 |
How model radiation of both solid wall and fluid£¿ | Harry Qiu | FLUENT | 2 | February 3, 2013 23:04 |
Defining Solid Zones Not working | elmcmaster | FLUENT | 3 | May 22, 2009 07:14 |
Multiple Solid Domains - Interfaces | Scott | CFX | 8 | July 31, 2008 15:20 |
