how to get such mass fraction
Old   April 12, 2005, 02:37
Default how to get such mass fraction
handou
hello. now, i am modeling a heat transfer flow. i want to get the mass fraction of the fluid in a certain temperature range. how can i deal with this problem? thanks.
Old   April 12, 2005, 04:44
Default Re: how to get such mass fraction
rom
the follwing udf can be run in interpreted mode and computes the fluid mass within tmin and tmax (K).
good luck rom
#include "udf.h"
#define Tmin 1200
#define Tmax 1500
DEFINE_ON_DEMAND(get_fraction)
Domain *d;
cell_t c;
Thread *t;
real mf,mft;
mf=0;
mft=0;
d = Get_Domain(ROOT_DOMAIN_ID);
thread_loop_c(t,d)
begin_c_loop(c,t)
if((C_T(c,t)>=Tmin) && (C_T(c,t)<=Tmax)) mft += C_R(c,t)*C_VOLUME(c,t);
mf += C_R(c,t)*C_VOLUME(c,t);
end_c_loop(c,t)
printf("\nfluid mass = %f kg",mf);
printf("\nfluid mass within temperature range = %f kg",mft);
Old   April 12, 2005, 06:57
handou
oh, thank you, rom. this really help me a lot
Old   April 12, 2005, 09:22
handou
hi, rom. i try to use this udf on my computer.it can be compiled successfully. but, when i try to execute it from "execute on demand" panel, there is no reaction at all. i want to know where is the result printed to? thanks!
Old   April 12, 2005, 09:59
rom
Sometime Fluent doenst get the printf command right. I tested the udf on my machine (WinXP Fluent6.2) and it worked. You can substitute the "printf" with "Message". This usually solves the problem but then the udf will not longer run in interpreted mode so you will have to compile it first.
good luck rom
mass fraction of species Lilly FLUENT 5 March 13, 2022 17:52
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
