coupled wall problem
Old   April 13, 2005, 07:05
Default coupled wall problem
Gerhard Hinterholzer
I use Fluent 5.3. My geometry consists of a non axisymmetric cylinder with a main axis along the z axis, where also the full gravity is acting. The cylinder ist divided in height into two parts with a wall at half height. This wall is modeled as a coupled wall. In the lower und in the upper cylinder there is a velocity in- and outlet. The lower cylinder ist heated from below. I expect a heat flow over the coupled wall (steel) from the lower to the upper volume, but this does not work. Can anyone give me a hint where i can have probably the problem?
Thanks Gerhard
Old   April 13, 2005, 12:37
Default Re: coupled wall problem
Evan Rosenbaum
Check your GAMBIT file to see if there are two faces at the intersection that need to be merged. If you named your interface wall and need to do a merge, a two-sided wall named "Wall" should show up in FLUENT.
Problem with wall function gregjunqua OpenFOAM 5 August 25, 2011 23:32
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
