3Gb switch Windows XP
Old   November 15, 2005, 05:41
Default 3Gb switch Windows XP
Simon
I'd be grateful if anyone can tell me whether Fluent supports the 3Gb switch under Windows XP.
I'm currently running Fluent in parallel mode on 2 32 bit HPxw6000 pc's each with 4Gb of physical RAM onboard. I can solve upto 3 million cells with this setup.
I have the 3GB switch activated on both pc's but Fluent doesn't seem to see it. Any attempt to load a 4 million cell test case aborts with an out of memory error.
I am thinking of moving to Linux to be able to access more RAM, but am unsure as to whether will this give me 6GB, or 8GB of usable memory.
I'd be grateful for any thoughts on this.
Thank you, Simon.
Old   November 29, 2005, 08:51
Default Re: 3Gb switch Windows XP
Tighe
The 3 Gb switch in windows still allows only 2 Gb of RAM maximum for one program. The other gig is useful because it keeps windows stable and running in the background. I have run both Algor and CFDesign with the switch and seen a greater ability to multitask but no more calculating power. Linux will allocate as much RAM as a program will consume so the pressure is on the Fluent software to properly allocate that much RAM. A good source for more information on this are the people at CFD++. They have great software and understand both operating systems well.
Best Regards,
Tighe
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
Clustering Windows XP 64 bit airfoil Siemens 4 August 16, 2006 18:20
