Grid interfaces in Fluent
Old   January 28, 2006, 01:48
Default Grid interfaces in Fluent
Omar Qazi
I am working on a simulation where I want to use a grid that is locally refined at selected points. I planned to carry out the refinement manually by generating the grid in parts and later assembling the grid by defining interfaces. Generally the number of nodes on ether side of an interface are different. I defined coupled interfaces to provide continuity.
The problem I am facing is that the the interfaces seem to be acting as walls in the simulation. The interfaces are generally normal to the incoming flow and the flow diverts at the interface. What am I missing?
Old   January 28, 2006, 18:55
Default Re: Grid interfaces in Fluent
Razvan
"Coupled" option is used only for fluid-solid interface (it means that Fluent will also calculate heat transfer, if any). When would you use such interface: let's say you want to calculate temperature distribution in a turbine blade, in which case solid region mesh is often very different from fluid region mesh (usually coarser), because same mesh will then be used for structural analisys in a dedicated code. So you will have to define a non-conformal interface at the blade surface, using "coupled" option.
But in fluid-fluid interface, all you have to do is define the interface without any other options.
Razvan
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
Fluent Grid Check: Left-handed & right handed face Haider FLUENT 3 March 22, 2009 23:01
Partitioning across Grid Interfaces David Hargreaves CFX 5 August 25, 2005 23:38
Error on defining grid interfaces at FLUENT Ridwan FLUENT 1 July 27, 2005 05:41
Grid for Fluent v.4 using Gambit? Ray Main CFD Forum 3 October 27, 1999 12:35
