Question on Fluent Post-processing
Old   March 29, 2006, 18:04
Default Question on Fluent Post-processing
Riaan
I have a circular outlet boundary (Pressure outlet), and I only need the averaged pressure values on a 30degree sector of the circle.
How do I go about clipping such a surface?
Thanks Riaan
Old   March 30, 2006, 17:10
Default Re: Question on Fluent Post-processing
Jason
Make sure your axis of rotation is setup correctly (Define->Boundary Conditions... pick your fluid volume and set the vector and intersection point of the line of rotation). Then you can clip the surface by going to Surface->Iso Clip... Do a clip of Grid and Angular location.
Hope this helps, and good luck, Jason
Ansys Post processing ano999 ANSYS 1 May 27, 2011 16:24
NO model vs post processing in coal combustion,CFX sakalido CFX 1 April 15, 2011 14:07
post processing for KIVA dirga Main CFD Forum 5 April 23, 2009 10:58
Fluent Post Processing Kulasekharan N FLUENT 0 February 18, 2008 02:54
Question on openning mesh from Fluent Derek Jing FLUENT 5 April 22, 2002 15:55
