March 29, 2006, 18:04 |
Question on Fluent Post-processing
I have a circular outlet boundary (Pressure outlet), and I only need the averaged pressure values on a 30degree sector of the circle. How do I go about clipping such a surface? Thanks Riaan |
March 30, 2006, 17:10 |
Re: Question on Fluent Post-processing
Make sure your axis of rotation is setup correctly (Define->Boundary Conditions... pick your fluid volume and set the vector and intersection point of the line of rotation). Then you can clip the surface by going to Surface->Iso Clip... Do a clip of Grid and Angular location.
Hope this helps, and good luck, Jason |
Ansys Post processing | ano999 | ANSYS | 1 | May 27, 2011 16:24 |
NO model vs post processing in coal combustion,CFX | sakalido | CFX | 1 | April 15, 2011 14:07 |
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 10:58 |
Fluent Post Processing | Kulasekharan N | FLUENT | 0 | February 18, 2008 02:54 |
Question on openning mesh from Fluent | Derek Jing | FLUENT | 5 | April 22, 2002 15:55 |
