May 10, 2006, 18:07 |
cavitation menu is not showing
When I want to define the 'multiphase Model' only half of the pannel is showing. In other words the 'Interphase Mass Transfer' is Not showing so I can't not choose 'cavitation' and its parameters. Pls somebody help me on this problem. FYR I am a novice of Flunent.
May 11, 2006, 01:54 |
Re: cavitation menu is not showing
Hi!
If you use Fluent 6.1 the menu should appear when you click on the "mixture model". In fluent 6.2 you must first set the mixture multiphase model then go to "Define-Phases" click on phase-1 and then click interaction. In the menu click "mass" and then click on "cavitation" - you define all the parameters here... Hope it helps MATEUS |
May 11, 2006, 12:43 |
Thanks a lot!
Mateus, I used 6.1 manual with 6.2 s/w. You help me a lot Thanks.
Plant Menu | Scott | Phoenics | 2 | October 6, 2006 04:51 |
compressibility and cavitation!! | xhliu1 | Siemens | 11 | March 16, 2005 07:19 |
Cavitation Simulation by CFD | Liu, L. | CFX | 2 | November 29, 2000 13:50 |
Cavitation Simulation by CFD | Liu, L. | Siemens | 2 | November 1, 2000 21:51 |
Cavitation Simulation by CFD | Liu, L. | Main CFD Forum | 7 | November 1, 2000 21:26 |
