Cleaning up operations
Old   May 22, 2006, 11:45
Default Cleaning up operations
Vidya Raja
I have a complex geometry that I'm trying to mesh. But there are many problems that I need to tackle before meshing, the first of which is cleaning up of short edges. I have tried using the FACE MERGE and VERTEX CONNECT options, but neither worked....... I'm assuming this is bcoz I do not know how to use it properly.
How do we decide which faces or edges to merge? When I looked at these specific edges in question, they are in such a way that they can't be merged with any of the adjacent ones. So how do I tackle the problem of cleaning up these edges?
Also, how do we check the skewness of the edges, faces etc?
Thanks, Vidya
Old   May 22, 2006, 12:28
Default Re: Cleaning up operations
Siddharth Khowala
hi Could u please share the geometry u wish to mesh because that would be helpful.Also if u wish to clean up edges(which i did not understand)my guess would be that u are either trying to delete them or join them,In the latter case thr is an option to join edges in gambit under create edge option.Please forgive my ignorance if the above seem to be trivial.
regards
Old   May 22, 2006, 13:42
Vidya Raja
Can you send me your email address so taht I can send you the file?
Thanks, Vidya
Old   May 22, 2006, 14:17
Vidya Raja
Hi, How can I delete the dges in question? that would distort my geometry. Is there any other leeway around this?
Thanks.
Linearized NS euqations: how to solve them?(problem with Matrix operations..) matteoL OpenFOAM Running, Solving & CFD 0 November 18, 2009 06:58
Need assistance in BC's for simulation of Vacuum cleaning nozzle bruce OpenFOAM Running, Solving & CFD 0 May 22, 2009 13:56
breakup model for cleaning processes Tim CFX 2 November 21, 2007 16:14
GET_GVAR operations? Cujo CFX 3 July 23, 2003 11:27
Floating Point Operations Per Second Rupp Carriveau FLUENT 0 May 29, 2003 12:39
