New to UDF Help really needed
Old   June 3, 2006, 02:29
Default New to UDF Help really needed
Amr
Hi All,
I am new to Fluent. I seeking a way to set a volumetric heat source that is changing with time. Also, I am seeking the same for a mass flow inlet. Could any body tell me how to do this from A to Z ??!
Cheers, Amr
Old   June 7, 2006, 11:35
Default Re: New to UDF Help really needed
Shanti
Hi
You can go through the UDF manual which is found at the following link. There are some examples similar to your problem. I am sending this thinking that you have an login access to it. If not, give me your e-mail id so that i can send it.
http://www.fluentusers.com/fluent/doc/ori/index.htm
Hope it helps, Shanti
Old   June 8, 2006, 14:27
Tom
The manual is good, but also big. I think you can save some time at first by focusing on DEFINE_SOURCE and DEFINE_ADJUST.
Best of luck!
-Tom
Old   June 9, 2006, 16:43
Amr
Hi Shanti,
Unfortunately I don't have access. Please send it to ayelbanhawy@yahoo.com
Sorry for my delayed response.
Cheers, Amr
Old   June 9, 2006, 16:44
Amr
Tom, I don't get it. Could you please elaborate.
Amr
Help needed on UDF for modification of default syamlal o' brien drag law caai9 Fluent UDF and Scheme Programming 9 August 20, 2014 08:52
Help needed with UDF writing (CREATIVITY WELCOME!) ximik Fluent UDF and Scheme Programming 0 May 13, 2011 12:13
Help needed with UDF writing (CREATIVITY WELCOME!) ximik Main CFD Forum 0 May 13, 2011 12:11
Parse error in UDF, URGENT HELP NEEDED!!! Boris Kloser FLUENT 2 December 12, 2009 03:16
Help with UDF for BC needed. Albert FLUENT 1 January 7, 2004 13:32
