June 26, 2006, 14:34 |
The residuals in FLUENT
Hello,everyone. I have a simple question about the residuals in FLuent. Are the resduals in FLUENT relative value or absolute value? I have finished a calculation with the residual of 10-4. When I continue the calculations, the residuals don't change any more. Is is a satisfied result? Need I change some parameters to get better result? Thanks!
June 28, 2006, 08:09 |
Re: The residuals in FLUENT
i think they are relative values , if u observe no change in the result of your residual then i think you should stop your iterations , but make sure u see these behaviour well below in negative directions like negative 5 or 6 or whatever u have set in th residual check
i hope i have answered you cheers |
June 28, 2006, 09:31 |
Thanks very much. Best wishes.
Abaqus - Fluent Coupling WITHOUT MPCCI | s.mishra | FLUENT | 1 | April 5, 2016 06:47 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 20:23 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
Fluent Parallel/Serial version..jump in residuals | Sandeep Abhyankar | FLUENT | 4 | January 10, 2000 09:57 |
