Mass from Mass fraction
Old   February 9, 2007, 06:50
Default Mass from Mass fraction
PK
Hi ,
How to get the mass of a species from C_YI( , , ) ; let's I have a mixture of 3 species : how to get the mass of a species i in a cell from just C_YI(cell,thread,i) ?
Thanks PK
Old   February 9, 2007, 08:10
Default Re: Mass from Mass fraction
Dmitriy
Hi PK,
Just multiply C_YI(c,t,i) by mass in the cell, which is (Density in the cell)*(Volume of the cell). You can do it using Custom Field Function and inspect it using Display/Countour. Alternatively, calculate it in UDF and store in a separate memory array (e.g., C_UDMI(c,t,mass_i)), i.e.
C_UDMI(c,t,mass_i)=C_YI(c,t,i)*C_R(c,t)*C_VOLUME(c ,t)
Something like this.
Regards,
Dmitriy
Old   February 12, 2007, 11:38
PK
Thanks a lot , It is working .
One more question ; About the value that should be given back by DEFINE_SOURCE in a UDF when removing species.
According to guide , it is value in kg/m3/s ; Does it make sense if with a surface (2D simulation) which is going to remove a quantity of species in M_remove (kg) a DEFINE_SOURCE udf gives back M_remove(kg)/area(of surface in m2) ? ->to have a "density of mass removed" .
Does FLUENT would multiply internally this value by the volume of the cell (C_VOLUME)?
Thanks
mass fraction of species Lilly FLUENT 5 March 13, 2022 17:52
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
