About drag coefficient of 2D circular cylinder!
Old   May 6, 2007, 23:50
Default About drag coefficient of 2D circular cylinder!
Haoyin Shan
Hi, all,
I am now working on the drag coefficient simulation of 2D circular cylinder. I have already checked lots of poster on this forum, indeedly, they helped me a lot.
My current simulation result is: for laminar flow (Re < 100), the simulation is pretty well comparing with experiment data.
I used SST K-omega model (the only model in Fluent 6.3.26 which can simulate transition) to simulate Transition (200<= Re <= 4000). I used UNSTEADY and specified adaptive time step at the beginning, after certain time (nearly one day), change to STEADY to get the convergence. The simulation is just fine comparing with the experiment. However, I can use second order to discretize only pressure, turbulent kinetic energy and specific dissipation rate. The momentum can not be discretized as second order to get convergence. Does this affect the result? If yes, any suggestion about how to improve this?
Thanks in advance!
Haoyin
drag coefficient of cylinder Avijit FLUENT 12 April 23, 2017 03:26
Drag Coefficient Verification around Cylinder MFerris CFX 44 May 11, 2015 18:27
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re lin OpenFOAM Running, Solving & CFD 3 April 16, 2009 10:50
