Multiphase Euler Granular Parameter
Old   May 30, 2007, 07:28
Default Multiphase Euler Granular Parameter
Javier
Hello all,
I am new in Fluent and CFD, and I am modelling a rotary dryer with Multiphase Euler Granular. I have two phases (one gas, one solid granular).GAS: 23,6 kg/s, Density= 1,2 kg/m3. SOLIDS: 10 kg/s, Density=700 kg/m3, Diameter=0.001. I should define all the parameter for the second phase, which is granular, and I donīt know which is actually the physical meaning of the following granular properties and the range that is usually used. I have read Fluent Userīs guide, but I don't understand how will be the behaviour of the second phase varying them, and how can I determine them experimentally:
- Granular Viscosity (does it substitute Material viscosity?) - Frictional Viscosity, Angle, Frictional Packing - Bulk Viscosity - Granular Temperature - Granular Conductivity - Solids Pressure - Radial Distribution - Drag function - Restitution Coefficients - Lift force
Maybe you could help me. Thanks a lot, and best regards,
Javier
Old   June 1, 2007, 06:29
Default Re: Multiphase Euler Granular Parameter
Javier
My concret questions are:
- Which range is used for these granular parameter? - If there is somebody who has worked with Euler Granular, could you please say me how determine these parameter for Fluent, and which range was used? - How can i determine these granular parameter experimentally?
Many thanks.
Javier
Euler granular multiphase ida FLUENT 7 October 7, 2013 14:09
euler euler multiphase modelling mdsvjpk FLUENT 0 July 23, 2011 11:11
euler euler multiphase modelling mdsvjpk FLUENT 0 June 14, 2011 11:50
granular multiphase models lurk FLUENT 4 January 23, 2008 04:51
granular multiphase model daninwin FLUENT 1 June 18, 2001 11:36
