How to create a surface of specified length for postprocessing? |
February 18, 2017, 09:54 |
Rep Power: 9 |
Hello everyone,
I am trying to consider the Heat transfer coefficient at some surfaces. How do I create a surface zone at the place where I want for examining results? If I try to create "new surface /plane" I have to put in 3 points to define the location in 3D, but this gives me the surface which is infinite in the length direction. Can someone tell me how I can only display a surface with specified x and y length? Best regards h0rst |
February 18, 2017, 22:38 |
Lucky
Rep Power: 66 |
Create the infinite surface as before.
Then do an iso-clip on that surface. It will create a new surface. You can clip using the mesh coordinates. |
February 19, 2017, 04:59 |
Rep Power: 9 |
Thank you, it worked perfectly out!
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 09:26 |
How to create a circular surface? | Jen | FLUENT | 7 | December 7, 2020 13:09 |
[ANSYS Meshing] Create new surface to existing CAD file | thomas. | ANSYS Meshing & Geometry | 0 | May 28, 2016 12:12 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
How to create permeable surface on inlet boundary? | Chilli83 | CFX | 10 | April 15, 2009 06:10 |
