urgent udf problem, please help
Old   August 7, 2007, 05:53
Default urgent udf problem, please help
mehrdad
Hi all I'm trying to compile a udf with my problem. when i copmile it, i get some errores from the fluent. one of this errores is "illegal use of this type as an expression". i don,t know why i get this error. some part of my udf is as follow: DEFINE_EXECUTE_AT_END(main_part) {
face_t f;
cell_t c0;
Domain *domain;
domain = Get_Domain(1); ----> Thread *t = Lookup_Thread(domain, ID);
Thread *t0 = t -> t0;
... the error is for the line that has ---->.
Thanks for your help.
Old   August 7, 2007, 06:52
Default Re: urgent udf problem, please help
Joe
You havnt defined ID.
Old   August 7, 2007, 07:17
mehrdad
thank you for your reply, i have defined it, but i didn't show it on my message. i have set it from the boudary condition panel.
Old   August 7, 2007, 07:23
Joe
This should work:
Domain *domain;
Thread *t;
Thread *t0;
face_t f;
cell_t c0;
t0 = t -> t0;
Old   August 7, 2007, 07:48
mehrdad
thank you joe for your replies. i examined your suggestion and it worked correctly. but i have faced with a new problem in my code. i try to dot product two vectores but it not work. this part of my code is:
... c0 = F_C0(f, t); F_AREA(A, f, t); deltemp = C_T_G(c0,t0); Qin = - 1.2 * ND_DOT(deltemp, A) / NV_MAG(A); ...
this error is at the final line of the\is code. and error is "not enough actual parameters for macro 'ND_DOT'".
UDF Problem ozgur Fluent UDF and Scheme Programming 18 January 17, 2016 14:40
Pressure profile UDF for unsteady-state problem? Mohsen Keshavarzian FLUENT 2 August 20, 2008 04:22
parallel UDF problem kerem FLUENT 2 June 20, 2006 06:56
Switch problem! using 2 custom udf laws at the same time HP FLUENT 0 September 15, 2004 09:48
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 10:22
