patching-initial temperature
Old   September 14, 2007, 10:14
Default patching-initial temperature
Lousa
hey all,
im having some trouble with patching. I have a rectangular domain, at which I want to define initial temperature 30 degrees C at the upper boundary, 20 degrees C at the lower boundary and I want the temperature to linearly decrease from 30 to 20 at the points inbetween. Can anyone help please?? Any suggestions would be greatly appreciated!
regards, Louisa
Old   September 14, 2007, 10:59
Default rephrase of the above
Lousa
hey,
I thought my problem is explained better this way:
im having some trouble with patching. I have a rectangular domain, at which I define backflow temperature 30 degrees C at the upper boundary, 20 degrees C at the lower boundary and I want the initial temperature to linearly decrease from 30 to 20 at the points inbetween. The fluid enters the domain from a "hole" and is at 15 degrees C initially. At the initial conditions, i put 15C? Then how can I make the initial temp of the domain (porous media) to decrease linearly? Can anyone help please?? Any suggestions would be greatly appreciated!
regards, Louisa
Old   September 14, 2007, 11:36
Default Re: rephrase of the above
Joe
Setting spatially varying initial temperatures is simple via an udf. Look in the udf manual for the section and example dealing with initial conditions.
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
