Tri and Quad Mesh
Old   November 3, 2007, 17:57
Default Tri and Quad Mesh
Sham
Hi all,
I am using Dynamic Mesh and found that Tri mesh is actually better to comply with dyn. mesh parameters. However, I feel with quad mesh we can have better control of the mesh.
Will the results make a different if we use tri or quad mesh? I also notice that with tri mesh we need a smaller time step than quad mesh? Could anyone pls explain.
Thanks.
Sham.
Old   December 3, 2007, 02:55
Default Re: Tri and Quad Mesh
Ramesh.K
As far as I know there is no difference in using a trinagulation or a quadrilateral meshes unless and untill u encounter a serious problems like the one with boundarylayer capturing or shock wave capturing where quad mesh will have more usage than the tiangulation. its based on the complexity of the underlying geometry we use either a quad mesh or a tri mesh, from both of these we are trying to calculate the fluxes and the derivatives at a point in the flow field.
bye
Ramesh
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] how can i delect the duplicate mesh line and nodes in interface between quad and tri? snailstb ANSYS Meshing & Geometry 10 September 26, 2013 08:19
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
