Changing RPM
Old   February 28, 2008, 16:31
Default Changing RPM
Amir Hossein Birjandi
Hi I have modeled a vertical turbine and I need the transient results. So I made a sliding mesh model. I want that the turbine starts from RPM=0 at t=0 and RPM increases at each time step to reach its actual RPM. In boundary condition I want to set variable RPM for one of my zones which is included the turbine. But I found that when I choose moving mesh I dont have this opportunity to set variable RPM or select UDF for that. Is there any way to change RPM by time in fluent for sliding mesh? my e-mail is amir.birjandi@gmail.com I would appreciate that if some one can help me.
Old   March 3, 2008, 14:35
Default Re: Changing RPM
Tito
You can only define velocity (transitional or rotational) of the mesh, not acceleration with the sliding mesh. Perhaps you have to use dynamic mesh instead.
Old   March 4, 2008, 00:51
mateus
You can very probably do this with an udf... Check the udf tutorial and manual...
Mateus
Extend Project 1.6-ext Binary Release for Mac OS X hjasak OpenFOAM Announcements from Other Sources 26 November 5, 2013 16:50
OpenFoam 1.6-ext - RPM build errors preibie OpenFOAM 12 September 8, 2011 03:12
energy changing associated with mass changing Martin duan FLUENT 0 August 6, 2011 12:42
RPM packages of OpenFOAM 1.7.1 for CentOS vnpenguin OpenFOAM Installation 0 November 14, 2010 12:51
RPM vs time for a turbine johnny FLUENT 0 November 10, 2005 04:00
