pressure-velocity-coupling in batch mode
Old   March 7, 2008, 10:07
Default pressure-velocity-coupling in batch mode
Ditschelping
I want to use the pressure-velocity-coupling method (Solve-Controls-Solution-Pressure-Velocity-Coupling: Coupled) but I want to define this setting via Journal-File.
I have tried to use
solve set p-v-coupling
in shell. But this way the p-v-coupled solver is not activated.
How can i activate this solving-method in bat-mode.
Thank You.
Old   March 10, 2008, 12:58
Default Re: pressure-velocity-coupling in batch mode
Remus
Try this command(s): ;begin solve/set p-v-coupling 23 ;end
where the different schemes are as following: 20 SIMPLE 21 SIMPLEC 22 PISO 23 Coupled You can also check this by drilling down in the TUI and you should be able to replicate the above set of commands.
Regards, Remus
Old   March 11, 2008, 03:15
Ditschelping
Thank you for your message.
I have tried this way several times. The Problem is, that in the GUI (solve - controls - solution) the coupling method isnīt displayed after i try to enable it like this.
Can it be, that the coupling is enabled, but it is noch displayed there, either?
How can I check if the coupling is enabled?
Thank you.
Old   March 12, 2008, 07:38
andy_au
I've used the same command many times before in batch mode but always used 24 rather than 23 (I only used 24 as it worked from trial & error) and I've had no problems
Old   March 12, 2008, 09:03
Remus
To get a summary of all settings, BCs, solver controls and more you can type this:
report summary
It is going to ask whether you want it exported to a file. Then you can open the file and look under Solver Controls for the Pressure-Velocity coupling. It's going to show the coupling method.
However, it is only when you're trying to change the P-V coupling through journaling that you don't get to see the P-V window switch in the GUI?
Old   March 13, 2008, 06:03
Ditschelping
thank you for your help. I have tried it out and it works.
Thank you very much.
Old   January 22, 2017, 11:01
Default commands for pressure velocity couple algorithms in TUI
kemin ali
kemin is on a distinguished road
solve / set p-v-coupling 20 #SIMPLE
solve / set p-v-coupling 21 #SIMPLEC
solve / set p-v-coupling 22 #PISO
solve / set p-v-coupling 23 #Coupled
source: TUI manual of Fluent
kemin is offline   Reply With Quote
Old   August 20, 2018, 14:09
James Wright
u2berggeist is on a distinguished road
For Fluent 19.0, the index for "Coupled" is 24 instead of 23 now.
u2berggeist is offline   Reply With Quote
CFX Pressure-Velocity Coupling Marco Pellegrini CFX 0 December 30, 2008 11:48
PRESSURE VELOCITY COUPLING??? student CFX 1 March 26, 2008 12:49
Pressure - velocity coupling student CFX 0 March 26, 2008 11:36
velocity pressure coupling Winston Gregorio Main CFD Forum 0 March 25, 2007 16:30
Velocity-Pressure coupling Diego Nogueira Main CFD Forum 3 July 18, 2004 13:39
