Locating points in a display
Old   November 22, 2008, 12:01
Default Locating points in a display
Nikhil Dani
Dear All,
Suppose there is a single phase liquid flow through a tube under a set of boundary conditions. Now, after the solution is allowed to converge, I wish to simulate a solid particle in the domain. Can that be done by altering the flow properties at a given location ( say by increasing the viscosity to a high value at that particular location, through UDF). I do not wish to use DPM for simulating solid particles.
Thanking you in anticipation,
Nikhil
Old   November 22, 2008, 12:25
Default Re: Locating points in a display
Nikhil Dani
Many apologies for the incorrect subject line. I have reposted the query under the appropriate subject.
contour display, some black points frank FLUENT 3 December 15, 2020 12:25
[Technical] Points Satish Undapalli (Satish) OpenFOAM Meshing & Mesh Conversion 7 May 8, 2008 15:19
Locating particles in airblast atomization (DPM) Prasad Dudhgaonkar FLUENT 1 May 31, 2004 21:43
VOF-locating the surface?? Kristine FLUENT 2 November 11, 2003 10:02
Maximum value at different points zahid FLUENT 0 March 16, 2002 08:13
