Steady or Unsteady
Old   January 5, 2009, 02:03
Default Steady or Unsteady
Amir
I want to run a simulation on Savonius like turbine. for using the MRF or Moving mesh method I should run steady or unsteady simulation?
The flow is steady on x-direction and the turbine is turning on z-direction.
Please give me some information...
Best regards.
Amir.
Old   January 5, 2009, 23:27
Default Re: Steady or Unsteady
Davy
depends on your needs. MRF can give you an approximate solution immediately but not as accurate as moving mesh method
Old   January 6, 2009, 00:02
Amir
Dear Davy,
Should I use steady or unsteady simulation? As I know my case is unsteady, however the free stream velocity is constant. But I'm thinking if the MRF or Moving mesh method use the time average so no need to run the unsteady simulation!
I appreciate your concentration,
Amir.
Old   January 13, 2009, 01:50
Anastasios
i think you should go for steady since your initial condidions are constant. Further more i suppose that this depends on what you want to examine in the results.
Old   January 13, 2009, 02:27
AMIR
Dear Anastasios,
I tried to run steady and unsteady simulations. while I'm running the steady one there is no problem, but when I try the unsteady simulation after clicking on start iteration there is error "non-positive volume exists".
I use the same mesh as I used for steady, while on steady-moving mesh there is no problem.
when i import the mesh into fluent after grid check also there is no problem, till i start iteration.
What is the problem and how I can resolve it.
regards,
Amir.
Old   January 13, 2009, 03:41
Anastasios
after you do grid check in fluent, see the value of "minimum volume" is it possitive or negative? please check it and reply to me in order to advise you what to do.
Old   January 13, 2009, 06:54
AMIR
Dear Anastasios,
I checked and its positive. As I mentioned before I can run simulation with this mesh for steady-moving mesh case. when I change it to unsteady after clicking the iteration it gives error "non-positive volume exist".
I don't understand how one mesh can give once error, once not.
best regards,
Amir.
Old   January 14, 2009, 02:26
Anastasios
Since this value is positive it means that your mesh is OK. Hence this error is not mesh related. When you switching to unsteady mode what is the time-step that you use for the simulation?
Old   January 14, 2009, 05:36
AMIR
Dear Anastasios,
When I use Unsteady the time step is 0.001145 second and 10 time steps.
the free stream velocity is 20 m/s and the rotation speed of turbine is 655 rpm.
Thank you so much,
Amir.
Old   January 14, 2009, 06:11
Anastasios
If you are using Gambit for the meshing of the geometry do a mech check in Gambit and see the value of skewness! A general rule is for this value to be smaller than 1. The ideal value should be close to 0.7. If your mesh fails this skewness check this means that you have to consider meshing the geometry with a different scheme. Please do this check and let me know.
Old   January 14, 2009, 06:26
  #11
AMIR
How I can check the value of the skewness in Gambit? and what I must do to resolve it?
Thank you so much,
Amir.
Old   January 15, 2009, 01:20
  #12
Anastasios Georgoulas
Is your geometry 2d or 3d?
Old   January 15, 2009, 07:23
  #13
AMIR
my geometry is 3D. I checked and the highest value of skewness is 0.83.
Old   January 16, 2009, 01:42
  #14
Anastasios
then its ok. i cant understand whats hapenning! And its very strange that it works for steady and not for unsteady!
You could probably ckeck by visual inspection if everything in your geometry is meshed or some parts are not meshed. I cant think of anything else. Sorry.....
Old   January 16, 2009, 07:04
  #15
AMIR
Dear Anastasios,
thank you for your interest, I will remesh it with this hope that it will work..
Regards,
Amir.
Old   January 18, 2009, 23:55
  #16
AMIR
Dear Anastasios,
I meshed again my geometry, this time with the maximum value of skewness "0.76", but again same problem while I click to iterate.
in the mesh in some parts I'm using tetrahedral and in some parts hex/wedge cooper. can this cause problem?
or I should do anything in fluent for this mesh..? Really I'm going crazy.
Old   January 19, 2009, 01:35
  #17
try using oly one kind of mesh elements i would go for tetrahedral. If you like send the .dbs file of the geometry in my email in order for me to take a better look of what might happens wrong. My mail is ageorg@civil.duth.gr
Steady needs unsteady. nico Main CFD Forum 0 September 21, 2007 04:50
steady/unsteady zwdi FLUENT 9 September 23, 2003 05:07
Steady/Unsteady Pravesh Kumar FLUENT 11 September 18, 2003 00:21
steady and unsteady Adler Phoenics 0 September 9, 2001 03:58
steady or unsteady thomi Main CFD Forum 4 May 13, 1999 05:05
