Interior BC problem when import into Fluent
Old   March 19, 2009, 09:46
Default Interior BC problem when import into Fluent
oscar
coolyihao is on a distinguished road
lets say i have a turbine, rect region 1, and rect region 2 (as shown below)..rect region 1 encounter whole turbine and rect region 2 encounter whole things(includes turbine and rect region 1)
I used rect region 1 subtract turbine = volume A
then I used rect region 2 suntract A (retain) = volume B
then i used volume mesh for A and B
i set the faces around the rect region 1 as INTERIOR.. but when i import into Fluent (error such as cannot change to interior becuz there is only one adjecent cell thread)
May i know how to solve it? because if i do not to set it as any boundary condition in gambit..it will automatically become WALL in fluent
THX
coolyihao is offline   Reply With Quote
Old   March 31, 2009, 20:18
panda is on a distinguished road
You may use "interface" instead of "interior", or, you should split region 2 to make sure A and B are connected such that you can define "interior" boundary between them.
panda is offline   Reply With Quote
Old   April 1, 2009, 01:09
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
If Gambit set your faces as wall, it means that they are not connected
I have a doubt about your second substract with retain
I would split rect2 with A.
clik on plugs-icon, the faces between 2 connected volumes should be pink
-mAx- is offline   Reply With Quote
Interior B.C. Problem Samaneh Zeighami FLUENT 6 September 8, 2012 05:06
import STL got problem fathan FLOW-3D 2 March 10, 2010 17:29
Problem of import fluent data to ilight fieldview seasoul FLUENT 3 September 9, 2008 22:36
interior angle problem Anthony Haroutunian FLUENT 0 March 27, 2008 09:36
import on fluent Valerio FLUENT 0 July 9, 2007 08:10
