how to set the fluent to show the 3D results in the xz plane?
Old   September 2, 2009, 03:59
Default how to set the fluent to show the 3D results in the xz plane?
poiu is on a distinguished road
my model is a 3D model
the fluent show my results in the plane of xy
i want to show the xz or yz plane, can you tell me how to set the fluent to show the results in the default way of xz plane?
i don't want to retate it in the result's picture by myself.
poiu is offline   Reply With Quote
Old   September 2, 2009, 05:24
-mAx-'s Avatar
Maxime Perelli
if it is just a question of view, then go to display/view
Old   September 2, 2009, 05:45
Smile
thank you very much!
Old   January 30, 2013, 04:54
zaynah K.
zaynah04 is on a distinguished road
hey Max,
can you please tell me how i display a 3D image in fluent ? for velocity contour
zaynah04 is offline   Reply With Quote
Old   January 30, 2013, 06:03
-mAx-'s Avatar
Maxime Perelli
you need to display velocity contour on a face.
you can create a slice for example
Old   January 30, 2013, 06:14
zaynah K.
oh i know this... i usually slice
but i wish to disply it in 3D insuch a way that we can see the shape and pattern inside the domain..
Old   January 30, 2013, 06:33
-mAx-'s Avatar
Maxime Perelli
then you need to enable "overlay" option in diplay/scene.
Once it is done, you can display sour shape and the contour will remain
Old   January 30, 2013, 06:37
zaynah K.
hi...
i got it.
but its not giving the proper resutl
Old   January 30, 2013, 06:51
-mAx-'s Avatar
Maxime Perelli
if you want to see your contour inside your domain, then you need to play with transparency (display/scene)
how to set CFL number in FLUENT xiaofish FLUENT 1 October 12, 2007 04:51
how to set fluent help yfai FLUENT 0 February 1, 2006 23:34
how to set two region in Fluent? Lu FLUENT 1 November 10, 2005 14:38
Level set and Fluent? markuwill FLUENT 1 June 3, 2005 12:34
How to set Water in fluent to compressible? Christian FH Biel FLUENT 3 October 29, 2004 08:06
