Problems with wall shear stress.
Old   September 18, 2009, 16:04
Question Problems with wall shear stress.
Jie Chen
xiexiehezuo is on a distinguished road
Hi, I am doing some simulation on non-Newtonian fluid flow through a stenosed pipe with a bypass pipe. I am very interested in the wall shear stress after the bypass. I add boundary layers at the walls, the inlet and the outlet, as well as the intersections. However, when I compute the wall shear stress, it doesn't seem to converge when I refine the mesh, especially the minimum value there.
I generate the mesh under GAMBIT. Can you give me any suggestions? How accurate does FLUENT give us in the sense of wall shear stress?
Another question is that when I want to get the minimum of wall shear stress, Fluent gives me two options: facet minimum and vertex minimum. What is the difference between them? How does FLUENT compute them? Which one is more reliable?
xiexiehezuo is offline   Reply With Quote
Old   September 22, 2009, 12:26
Question How to get a converged solution for wall shear stress?
Jie Chen
Hi, I might not demonstrate my problem clear.
I have boundary layers near the walls and at the intersections. However, when I decrease the size of the first raw in the boundary layers while keep the major part of the mesh to be the same, I don't get a converged solution for the wall shear stress. I am interested in the minimum of the wall shear stress near the intersections. However,the values keeps changing when I refine the mesh. My case is laminar flow. This confuses me a lot.
Does anyone have any suggestion?
calculate y+ and u+ -how to get wall shear stress? Ralf Schmidt Main CFD Forum 18 September 17, 2019 03:23
Unsteady Wall Shear Stress Data Repoting Arash FLUENT 1 February 13, 2008 14:36
relationship between wall shear stress and TKE winter FLUENT 0 December 11, 2007 17:11
Wall shear stress in a UDF Jafri FLUENT 3 December 6, 2002 17:29
Flux depending on wall shear stress in Fluent 5.2 Andreas Borg FLUENT 0 June 7, 2000 06:27
