October 6, 2009, 11:22 |
aqueous solution droplet modeling
Hi dear all,
I don't have much experience in DPM modeling, but now I need to model the evaporation process of an aqueous (water) solution when it is injected into a hot gas flow (like in a drying process). My material, the solute M, is solved into water, and then the solution will be sprayed into a hot gas to let all the water evaporate so that M (solid) could be obtained. I checked Fluent manual, and there seems to be two options for modeling the water solution droplets: droplet particles with a volatile component fraction specified, or the multi-component particles with the mass fraction specified. Which one I should use? or, if a user-defined function has to be used, could anyone give me some ideas about how to model this process? thank you so much in advance! yingying |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
Doubt on Implicit Methods | analyse In India | Main CFD Forum | 10 | March 9, 2007 03:01 |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 11:48 |
UDF for modeling droplet splash | zhzhguo | FLUENT | 1 | September 22, 2005 22:17 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
