February 12, 2010, 01:45 |
validation
mach
Hi all and respected sirs,
I am working on a problem ( of a geometry on the exhaust side) with experimental data available. But my inlet and outlet pressures ( I've used pressure inlet and pressure outlet conditions ) per se are very close to each other and also to atmos pressure. Inlet - 14.76 psi & outlet - 14.51 psi. Though computed pressures are matching within 2% of experimental values will this narrow pressure range create a road - block for my problem? ( i have used Gambit & Fluent). Thanks in advance and take care.............. |
Air-Water VOF Depressurizing Bottle Validation | Bak_Flow | FLUENT | 0 | January 26, 2009 12:57 |
Oscillating flow around cylinder validation error | Zak | FLUENT | 0 | September 22, 2005 16:09 |
Spray combustion validation | David | FLUENT | 0 | December 20, 2004 12:51 |
Urgent: RAE 2822 validation | NID | Main CFD Forum | 0 | September 3, 2004 10:34 |
code validation | Ma | Main CFD Forum | 8 | February 14, 2002 10:25 |
