How to create two fluid zones?????
Old   May 23, 2010, 10:59
Default How to create two fluid zones?????
Rahul
rahulangal is on a distinguished road
i hv an problem creating two zones of fluid in fluent...
the problem is ..
i hv to define two fluids in same container below 10% is fluid1 & above 90% is fluid2 ...
can any body plz help me ???
rahulangal is offline   Reply With Quote
Old   May 25, 2010, 01:19
-mAx-'s Avatar
Maxime Perelli
return in your Mesh-software, and define them as separated fluid zone
Old   May 26, 2010, 03:32
Default Thanx
Rahul
hay.. actually i defined fluid zones in gambit but i want to apply boundry condition in fluent, how can i apply zone bc if i m using a transport & mixing model for my problem???
Old   May 26, 2010, 04:02
-mAx-'s Avatar
Maxime Perelli
if your fluid zone is well defined in Gambit (Specify Continuum), then you are able to see this fluid zone in the BC panel from fluent.
Old   May 27, 2010, 10:44
Default thanx...
Rahul
hay thanx for ur reply..
i cud see the fluid zones in fluent BC panel but, how to define dat bc in transport & mixing reaction model.. wud u plz elaborate????
Old   May 28, 2010, 01:16
-mAx-'s Avatar
Maxime Perelli
There are tutorials about transport and mixing planes. Check them
how to create a temperature dependant fluid Amy CFX 4 October 18, 2009 19:30
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Fluid Structure Interaction Apollo FLUENT 8 July 7, 2004 17:54
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
surface-creation on 1 of 2 overlapping fluid zones Volker Pawlik FLUENT 0 November 17, 2000 05:15
