July 21, 2010, 16:14 |
Patching with TUI
Hello.
Lately, I've been doing a lot of Fluent scripting using TUI commands in journal files. In general, I first learn about commands and their options by executing them interactively with the TUI. Once I understand the command and arguments and the order they must appear, I construct journal files with a simple text editor. For example, a simple journal file might look like: solve initialize initialize-flow q q (I realize these entries can be placed on one line. I tend to put them on separate lines until I fully understand the ordering. Then I collapse them.) Today I am trying to create journal files with TUI commands to initialize portions of my domain with the patch command. Specifically, I want to patch certain registers that have previously created with another journal file. Here’s what I’ve got so far when I explore the patch command interactively: solve patch Then I hit enter to see what the first argument is. The first argument is “Domain” and my options are “air” and “mixture” (it’s a two-phase problem). (I find this confusing because these options are related to phase and not domains. The GUI panel has them under the Phase pull down menu, as expected. But whatever.) I select “mixture” and proceed. The next argument is: cell zone id/name(1) [()] What do I do here if I do not want to patch an entire domain? I’ve been just hitting enter, assuming that doesn’t select any specific zone. Is this correct? If not, how do I not choose any zones. The next options are the register options, and they appear as follows (I have 5 registers defined): register id/names (1) [0] register id/names (2) [1] register id/names (3) [2] register id/names (4) [3] register id/names (5) [4] register id/names (6) [()] This is where I get stuck. I’m assuming this is where I choose which register I want to patch, but what information is expected for each entry? Register ID? Register name? No matter what I do, I’m always prompted with all six lines above, even if I enter a valid register ID after the first prompt. How do I specify just one register and proceed? Sometimes, when I think I’ve entered things correctly (including hitting enter after the zone id prompt), the patch initialization occurs for the entire domain, not the desired register. Any insight anybody might have would be greatly appreciated. BTW, I'm using Fluent 6.3.26, but I don't think it's any different with Fluent 12.x. Regards. Last edited by Lovermore; July 21, 2010 at 16:15. Reason: Updated information |
July 22, 2010, 22:28 |
Mas
Here is one example for marking a sphere of 5mm radius at 3D coordinate 1,2,3 and patching 1500K temperature to it.
/adapt/mark-inout-sphere yes no 1 2 3 5 /solve/patch () 0 () temp 1500
<Mas> |
command line, patch, tui |
TUI command for patching region | Tristan Collins | FLUENT | 3 | May 6, 2019 06:19 |
TUI Commands from GUI? | Carlos | FLUENT | 6 | May 22, 2013 18:05 |
Sover setting with TUI | junbbung | FLUENT | 0 | August 20, 2009 00:43 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Define animate using TUI | Zurlugh | FLUENT | 1 | July 24, 2008 08:55 |
