how to calculate the viscous and inertial resistance coefficients?
Old   March 6, 2010, 11:42
Default how to calculate the viscous and inertial resistance coefficients?
Omur
omurakbayir is on a distinguished road
I am working on a fuel element.
The fuel element structural material is graphite in the form of right hexagonal prism, 7930 mm high and 360 mm across flats. It has 108 coolant holes with 15 mm diameter. Coolant holes run parallel through the length of the prism.
I need to define both viscous and inertial resistance coefficients.
I have not any experimental values about pressure and velocity.
Please told me how to calculate the viscous and inertial resistance coefficients.
Which method suitable for my problem to derive viscous and inertial loss coefficients?
1. Method: Deriving Porous Media Inputs Based on Superficial Velocity, Using a known Pressure Loss.
2.Method: Using the Ergun Equation to Derive Porous Media Inputs for a Packed Bed
3.Method: Using an Empirical Equation to Derive Porous Media Inputs for Turbulent Flow Through a Perforated Plate.
Or, Are there any empirical equation to derive calculate the viscous and inertial resistance for my problem?
omurakbayir is offline   Reply With Quote
Old   November 22, 2010, 22:36
Lightbulb
oky
Oky Andytya
oky is on a distinguished road
would you like give some example how to calculate the inertial and vicous resistace except from fluet user's guide.
Thank you.
oky is offline   Reply With Quote
Viscous resistance coefficients in porous medium fpingqian FLUENT 50 June 26, 2019 01:55
Inertial and viscous coefficient for porous media franzdrs Main CFD Forum 6 September 15, 2013 23:33
viscous and internal resistance coefficient in porous media bansal_vikas1 FLUENT 12 October 6, 2010 08:28
URGENT-viscous and inertial coefficients Louisa FLUENT 0 September 9, 2007 11:31
Defining Viscous and Inertial Resistance Coeff.s sean FLUENT 2 July 12, 2001 05:02
