November 26, 2010, 09:08 |
Standard k-eps with UDF/UDS
Andreas Håkansson
I am trying to implement turbulence models in FLUENT using UDS/UDF. As a first step I tried with just implementing the Standard k-epsilon. However I cannot get it to work. In the first step I add two UDS variables and let them have the same diffusivites and sources as k and epsilon but I use the ordinary k and epsilon in the equations for UDS0 and UDS1. Then I patch UDS-0 and UDS-1 with k and epsilon respectively. What I would expect is that my UDS-0 and UDS-1 would keep like k and epsilon. Instead they quikly get very different and I even get negative values for UDS-1 (“epsilon”). I would be very thankful if someone could have a look and see if I am missing something in my implementation. #include "udf.h" #include "math.h" /* DEFINES CONSTANTS FOR THE TURBULENCE MODELS */ const real sigmaK = 1; const real sigmaEps = 1; const real C1eps = 1.44; const real C2eps = 1.92; DEFINE_TURBULENT_VISCOSITY(user_mu_t, c, t) { real mu_t; real rho = C_R(c,t); real k = C_K(c,t); real eps = C_D(c,t); //real k = C_UDSI(c,t,0); //real eps = C_UDSI(c,t,1); mu_t = M_keCmu*rho*SQR(k)/eps; //mu_t = 0.12*rho*SQR(k)/eps; return mu_t; } DEFINE_DIFFUSIVITY(k_diff, c, t, eqn) // Diffusiviteten för k { real mu = C_MU_L(c,t); real mu_t = C_MU_T(c,t); real diff; diff = mu+mu_t/sigmaK; return diff; } DEFINE_DIFFUSIVITY(eps_diff, c, t, eqn) // Diffusiviteten för epsilon { real mu = C_MU_L(c,t); real mu_t = C_MU_T(c,t); real diff; diff = mu+mu_t/sigmaEps; return diff; } /* 2D-VERSION OF THE k SOURCE-TERM*/ DEFINE_SOURCE(k_source_twod, c, t, dS, eqn) { real rho = C_R(c,t); real eps = C_D(c,t); //real eps = C_UDSI(c,t,1); real mu_t = C_MU_T(c,t); real Gk = 2*mu_t*(C_DUDX(c,t)*C_DUDX(c,t) + 0.5*(C_DVDX(c,t)+C_DUDY(c,t))*(C_DVDX(c,t)+C_DUDY( c,t)) + C_DVDY(c,t)*C_DVDY(c,t) ); real source = Gk - rho*eps; //dS[eqn] = 0.0; return source; } /* 2D-VERSION OF THE EPSILON SOURCE-TERM*/ DEFINE_SOURCE(eps_source_twod, c, t, dS, eqn) { real k = C_K(c,t); real eps = C_D(c,t); //real k = C_UDSI(c,t,0); //real eps = C_UDSI(c,t,1); real mu_t = C_MU_T(c,t); real rho = C_R(c,t); real Gk = 2*mu_t*(C_DUDX(c,t)*C_DUDX(c,t) + 0.5*(C_DVDX(c,t)+C_DUDY(c,t))*(C_DVDX(c,t)+C_DUDY( c,t)) + C_DVDY(c,t)*C_DVDY(c,t) ); real source = C1eps*eps/k*Gk-C2eps*rho*eps*eps/k; //dS[eqn] = 0.0; return source; } |
fluent, turbulence models, udf, uds |
Standard convergence limit in FLUENT 6.1 | Henrik Ström | FLUENT | 3 | December 20, 2005 08:48 |
y+ value too low for use in standard wall function | Allan Cross | FLUENT | 3 | August 26, 2005 03:11 |
about the unit of the standard state enthalpy!! | KEVIN | FLUENT | 3 | March 25, 2004 08:32 |
Standard wall function vs Two layer model | C. ORTEGA | FLUENT | 0 | July 7, 2003 08:35 |
table and standard inlet condition | N.A. Beishuizen | Siemens | 0 | August 29, 2001 05:22 |
