Two equation turbulence models solver settings
Old   March 5, 2011, 20:49
Default Two equation turbulence models solver settings
truffaldino's Avatar
truffaldino is on a distinguished road
I will be grateful for your help. I am trying to make to converge solution for a low Re flow past to 2D airfoil with Realizable KE (wall enchanced treatment) and KW/KW SST transitional models as well.
There is no problem with convergence for one equation SA model and results are more or less satisfactory, but once I switch to 2 equation models I am going in a trouble.
I have checked y+, it is within the limits .1 to 1.
So, there could be two reasons for failure
1) These models are not suitable for analysing airfoils at Re about 10^5
2) My solver setting are wrong
Could the second be the case?
I will be grateful if you could help me:
Here I list the solver settings
__________________________________________________ _______
Steady
Pressure Based Implicit Formulation
Absolute velocity formulation
Green-Gauss Cell Based Gradient option
Pressure_Velocity coupling SIMPLE
Discretization
Pressure PRESTO!
Momentum SECOND ORDER UPWIND
Turbulent kinetik energy SECOND ORDER UPWIND
Specific dissipation rate SECOND ORDER UPWIND
Underrelaxation factors:
pressure .3
density 1
body force 1
momentum .7
Truffaldino
truffaldino is offline   Reply With Quote
the differences between turbulence models agungwp FLUENT 6 July 1, 2018 03:02
Turbulence models Reza Imani Main CFD Forum 7 April 8, 2016 09:15
k-e turbulence model and energy equation Blob Main CFD Forum 0 May 29, 2009 08:35
Coupled solver energy equation problem lucioantonio FLUENT 0 April 3, 2009 10:21
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 04:34
