February 2, 2016, 20:32 |
Meshing a wind turbine blade
numan
Rep Power: 11 |
Hi guys,
I am trying to validate my numerical method using NREL Phase VI blade in ANSYS FLUENT, but I am having hard times with meshing. I am using the standart meshing component of ANSYS. I just define face sizing, body sizing and infilation, I barely get 0.9 skewness having 12 M of mesh elements. I tried different sizing and methods, but still I can't increase the mesh quality. I have attached the picture of the fluid domain and other mesh sizing details. Do you have any advice? My power output results are arround %20 worse than experimental results. What should be the range of Y+ for k-w SST model? One more thing, the rotation direction of the Moving Domain inside is +z, that it true right? Thank you. |
February 4, 2016, 21:27 |
Aja
Rep Power: 14 |
Value of Y+ should be equal to 1.
It seems that rotation direction of the Moving Domain is right. Did you use structure mesh in computational domain? |
February 5, 2016, 22:16 |
numan
Rep Power: 11 |
Thanks for the response.
Nope I used unstructured mesh. Since the blade has a complex geometry, I guess it is almost impossible to use structured mesh. Do I need to learn to use ICEM CFD or some other meshing software for meshing? It seems very difficult to get a quality mesh with ansys meshing:/ And btw, the wind turbine blade should be stationary wall and not moving wall right? I just have to rotate the moving frame? |
February 6, 2016, 15:21 |
#4 | |
Aja
Rep Power: 14 |
I use Gambit but I am agree with you about "Since the blade has a complex geometry, I guess it is almost impossible to use structured mesh" But i had seen a few tutorial about meshing of wind turbine in Gambit. Also Did you study the following links and download them? https://www.google.com/?gws_rd=ssl#q...2FWind+turbine Above links are useful. there is a youtube link.... Last edited by aja1345; February 7, 2016 at 13:27. |
February 9, 2016, 18:55 |
numan
Rep Power: 11 |
thx for the responses, it helped me.
Strangely, if I use patch independent method (using tetra mesh), skewness and orthogonal quality values get much better, but mesh looks generally awfull. So, should I still use it? |
Anlysing and Calculating the power output from a wind turbine blade | mrswordf1sh | FLUENT | 1 | July 13, 2017 01:42 |
3D wind turbine blade analysis | mrswordf1sh | FLUENT | 0 | April 4, 2015 20:17 |
[ANSYS Meshing] wind turbine simulation meshing problem | maxwell94 | ANSYS Meshing & Geometry | 0 | January 26, 2014 13:06 |
Can I use Turbogrid to mesh a wind turbine blade? | Henry Liu | CFX | 10 | November 10, 2011 05:41 |
Inlet Flow Velocity or pressure gradient - modeling of a Wind Turbine Blade case | LittleBart | Main CFD Forum | 5 | January 10, 2011 15:07 |
