Blood flow analysis
Old   May 20, 2011, 02:19
Default Blood flow analysis
Govindaraju
kmgraju is on a distinguished road
Dear friends
I am doing blood flow analysis in artery in CFX. I modelled a simple cylinder as a flow. I apply the properties of the blood and set the reference pressure 1 atm.
I am doing steady flow analysis first.Flow is positive Z direction . The Boundary conditions are
Boundary type : opening
Under Mass and momentum> Cartesian velocity has been selected.
In the field W , The input velocity is U= Umax*(1-r^2/R^2)
Outlet:
Opening type
opening pressure and direction: ? ( what shall I put _ Help me here){ I put 0Pa}
Global Initialization :I put "U' In the velocity field W
Static pressure : ? ( help me ){ I put 0 Pa}
When I saw in medical article, the systole and diastole pressure has been mentioned in terms of mm Hg ( example 70mm Hg or 110 mm Hg -approx: 9210 Pa or 14473 Pa) .where can I see this pressure in the simulation. How can I set up the BC and parameters in such analysis.
Note: I did simple analysis But I could not find the huge value of pressure. I found approx 150 Pa - 200 Pa
Why?.
Please Help me
Thank you
Regards
Govind
kmgraju is offline   Reply With Quote
Blank white space in flow analysis? Welshnathan Phoenics 1 March 17, 2011 13:10
Pipe Flow Analysis akshayygarg FLUENT 3 March 4, 2011 08:57
FLUENT BLOOD FLOW RATE Christoforos FLUENT 0 September 18, 2008 10:08
blood flow simulation start-up hints please olumide olododo Main CFD Forum 4 May 31, 2004 11:33
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
