Tutorial Phase separation FLUENT (HELP)
Old   July 18, 2011, 21:01
Default Tutorial Phase separation FLUENT (HELP)
wibi ario
sincity is on a distinguished road
i need some tutorial about phase separation (multiphase fluid) from FLUENT thanks.
sincity is offline   Reply With Quote
Old   July 19, 2011, 22:16
wibi ario
dear mr. sadeghi
let me introduce myself, i'm undergraduate student in one of indonesian university my major is mechanical eng. my final task is about modelling gravity separator which use three phase of fluid (gas-oil-water) i'm using FLUENT as my CFD code...i want to ask some question about modeling three phase in FLUENT, would you help me??
Old   July 19, 2011, 22:38
eng_s_sadeghi's Avatar
eng_s_sadeghi is on a distinguished road
ok.
for fluid seperation, you should use vof 3phase model. also you should enable gravity.
they will seperate by time, after initial condition. the point is that you should use unsteady solution to could converge.
Saeed Sadeghi
Ansys Fluent CFD Consultant
eng_s_sadeghi is offline   Reply With Quote
Old   July 19, 2011, 22:44
wibi ario
using VOF for my model of my three phase simulation....should i add UDF for that, or not???because i read in FLUENT user guide that if i have more than one secondary phase i should adding some UDF called phase domain index???...would you explain it to me?? i'm very confusing should i use UDF or not for the three phase simulation
Old   July 20, 2011, 00:47
There is no need to UDF in this step.
you should just enable 3phases and run as an initial solution.
then you can add more details such as drag, lift, surface tension between phases, etc.
Saeed Sadeghi
Old   July 20, 2011, 01:16
wibi ario
i've tried in so many ways doing the simulation but why i didn't have my interface correctly.
here is my set up, i use VOF multiphase model
fluid: gas--->primary
oil ---->secondary
water--->secondary
boundary condition: inlet--->mass flow inlet
outlet--->outflow
implicit VOF scheme
gravity enabled
k-epsilon standard wall function
specified operating density enabled, PISO,PRESTO, Unsteady state
so i beg for you mr. sadeghi if you have been doing some multiphase flow like this you could give me an assistance or maybe you didn't but you have colleague who was an expert in gas-oil-water separator maybe you could connect me to him/her. thanks mr. sadeghi. (i almost did this for two years and no results)
Old   July 20, 2011, 03:25
wibi ario
i just need your guidance if you mind, i'll do it by myself. mr.sadeghi do you have a colleague that expert in this topic??
store separation tutorial haider FLUENT 2 June 29, 2014 08:53
Fluent SI engine tutorial problem Jonny6001 FLUENT 4 January 22, 2012 19:26
How to find the separation point in fluent caohan FLUENT 3 April 8, 2010 13:48
Does anyone has the case & dat file for tutorial of ansys fluent 12 zhang.limin Main CFD Forum 0 March 2, 2010 13:03
Request for pipe bifurcation fluent tutorial case Giorgos Momferratos FLUENT 0 October 20, 2008 15:10
