pipe flow problem
Old   August 5, 2011, 08:48
Default pipe flow problem
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
I try to simulate a pipe with a small sphere in the middle of the pipe. The setup is axisymmetric / 2D.
Now, if I mesh (ANSYS meshing) the pipe without the sphere (circle in 2d) everything works. When I add the sphere, use the boolean operator to cut the sphere from my pipe, meshing seems to do strange things: In Fluent the mesh->check shows:
Domain Extents:
x-coordinate: min (m) = 0.000000e+00, max (m) = 5.000000e-02
y-coordinate: min (m) = -1.910449e-19, max (m) = 4.000000e-03
Volume statistics:
minimum volume (m3): 3.118485e-12
maximum volume (m3): 2.481858e-10
total volume (m3): 1.516363e-06
minimum 2d volume (m3): 2.981272e-09
maximum 2d volume (m3): 1.610946e-08
Face area statistics:
minimum face area (m2): 4.314410e-05
maximum face area (m2): 1.744247e-04
Checking mesh..............
WARNING: Invalid axisymmetric mesh with nodes lying below the x-axis........................
Done.
WARNING: Mesh check failed.
which means, that meshing put some nodes below the x-axis (1.910449e-19 !!!) for some reason. Any ideas why that could happen?
RodriguezFatz is offline   Reply With Quote
Old   August 8, 2011, 09:46
husker is on a distinguished road
Can you upload a few pictures Rodriguez?
husker is offline   Reply With Quote
Old   August 9, 2011, 07:59
Philipp
Hi husker,
Thanks for offering help. I have no clue what the problem was, but creating the model a second time solved it!
Pipe flow with obstacle - HELP Min FLUENT 6 January 31, 2017 14:28
3D Swirl flow in the pipe: convergence problem Sachin U. Nimbalkar FLUENT 5 December 22, 2016 01:34
Large Valve Flow Analysis - Inflation Problem sercan85 ANSYS Meshing & Geometry 2 June 1, 2010 14:02
air flow in pipe with heat problem keng Main CFD Forum 1 March 5, 2010 10:40
stepped pipe flow Tom Cloutier Main CFD Forum 0 April 20, 2003 13:19
