Reynolds Stress Model
Old   November 2, 2011, 10:55
Default Reynolds Stress Model
Deepchand Singh Negi
deeimproptus is on a distinguished road
Working on flat plate with projections with jet impinging on it. Not pretty sure which model to use in Reynolds stress model -Linear Pressure-strain -Quadratic Pressure-strain -Low-Re Stress-Omega Tried with Low-Re Stress-Omega with second order upwind scheme but all the stresses along with KE and dissipation are oscillating. Played with it by reducing under-relaxation but oscillation are persistent. Do suggest...????
deeimproptus is offline   Reply With Quote
Old   November 3, 2011, 01:30
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
what is the maximum yplus in the domain. Quadratic Pressure-strain model is good, but it uses the epsilon as scaling variable, which might introduce error in solution, as it is well known that epsilon based models do not capture seperation and amount of seperation accuratly. On the other hand with omega based model, one can capture the boundary layer seperation more accuratly.
Aslo please refer to new model which uses the omega based model in near wall and Quadratic Pressure-strain model in the core flow. BSL-omega/SSG model by DLR
If you want to model the transition from laminar to turblence then use the three equation model by walter or metner gamma thetha model.
Far is offline   Reply With Quote
Old   November 3, 2011, 01:36
yplus is much less than 1
roughly around 0.33
I guess i have to give high initial guess values for dissipation
Old   November 3, 2011, 03:23
Far
Sijal
keep aspect ratio less than 100 (preferbly less than 50) and use double precision solver.
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
UDF in Re stress model Jihwan FLUENT 0 February 28, 2007 03:49
Any mesh limitation for SSG Reynolds Stress Model? Sam Main CFD Forum 1 October 13, 2005 12:34
Algebraic Stress Model and Collocated grid Keur Main CFD Forum 0 May 31, 2005 21:46
Reynolds Stress Model HC Lin FLUENT 0 October 7, 2002 18:45
