postprocessing problem of heat exchanger model
Old   December 8, 2011, 06:56
Default postprocessing problem of heat exchanger model
xuzhenyuan
xuzy0223 is on a distinguished road
i am a new to the fluent. now,when i finished the case using heat exchanger model,i just get the temperature contour of primary fluid(air),but i don't know how to obtain the result of auxiliary fluid(water).FLUENT help tutorial don't mentioned this detail.
so my question is whether the temperature contour of auxiliary fluid in heat exchanger model can be displayed in fluent postprocessing? if it can be extracted,how do it?
xuzy
xuzy0223 is offline   Reply With Quote
Old   December 9, 2011, 06:58
delaneyluke is on a distinguished road
The heat exchanger model in Fluent is not a multiphase model.
What i mean to say is that you are still solving the primary fluid (continuity, momentum and energy) and then adding the auxillary fluid through the heat exchanger model which calculates the exit temp of aux fluid using 1-D heat transfer convection.
So to answer your question, you will not get a temp contour of your aux fluid.
The only information for the aux fluid is available under "Reports>Heat exchanger model"
Regards
Luke
delaneyluke is offline   Reply With Quote
Heat Exchanger Model andrey_rushin FLUENT 1 November 17, 2011 05:38
[GAMBIT] problem with meshing a heat exchanger hittie ANSYS Meshing & Geometry 6 November 19, 2010 18:52
How to explicitly model a heat sink pandora FLUENT 1 August 18, 2010 12:36
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
heat exchanger problem pratap FLUENT 0 June 4, 2005 06:33
