negative cell volume detected (dynamic mesh analysis) |
January 2, 2012, 21:10 |
noken
dear all of FLUENT user
i think i'm facing a problem now with my dynamic mesh analysis simulation, i dont know why but this error come almost in my simulation. did i do something wrong please need your help, here is some crop picture of my simulation... |
January 3, 2012, 18:53 |
Your moving mesh set up is not well defined.
After a number of iterations, cells get negative volumes=> remeshing due to your moving mesh creates bad cells and Fluent cannot follow the simulation. Make a preview of the deforming mesh motion if you can or verify where the bad cells are to understand where the moving part of your geometry is creaing bad cells. |
January 3, 2012, 21:49 |
noken
thanks for the reply bigben, but i'm newbie in moving mesh simulation, would you tell me about how to do that??
January 4, 2012, 18:54 |
There are 3 differents moving mesh. Which one are you using: Remeshing/deforming/layering?
Give me your email, I may have some pictures showing how to do it. |
May 13, 2012, 08:37 |
negative cell volume detected during mesh motion preview
rauf
hi.. I am having the same problem like those other guys above there...can u help me how to solve the problem? i was doing a simulation of compression until expansion stroke in combustion chamber of SI engine
May 13, 2012, 17:10 |
which deplacement do you have? Which kind of cells do you have?
make a picture of you have and what kind of deplacement you want on it to give me an idea |
May 14, 2012, 01:39 |
#7 | |
rauf
please help me..i am doing this analysis for my undergraduate project thanks |
May 15, 2012, 06:09 |
Reffering to ur picture, ur mesh is purely hexa/quad, only layering can be applied starting at the botom of the "Piston".
Did you mesh the piston thickness? (just for understanding) If you want to remesh your volume, you need to mesh it in tetra and not in quad. So what did you do? When is the error appearing? |
February 20, 2013, 08:43 |
Hey Bigben.......here s my email id...jameil.sk@gmail.com
Can u send me some screen shots of how to make the remeshing,layering and smoothening work?? |
August 23, 2013, 05:15 |
#10 | |
sugumar vigneshwaran
suguaspire@gmail.com Thank you |
April 5, 2015, 22:15 |
#11 |
sanjeet Limbu
Rep Power: 11 |
I am facing issue of negative volume
i am using 2D planer mode - for compression stroke simulation : so the piston line - boundary move to compless inside fluid using the UDF |
March 28, 2016, 03:11 |
#12 |
Arif Shafiq
Rep Power: 11 |
June 26, 2016, 14:08 |
#13 | |
ronnie wang
Rep Power: 10 |
I am having the same dynamic mesh problem too. Best regard Ronnie sdsuronnie@gmail.com |
July 25, 2016, 01:39 |
Negative cell volume
#14 |
Dear Bigben,
Am working on Gerotor oil pump analysis , Am facing a negative cell volume error while doing a preview mesh motion. I want to know is it any command is available to display or view a negative cell to redefine my mesh again. Regards, Ganesh.t ganesh.t@sfl.co.in |
March 27, 2017, 16:58 |
#15 | |
Kubilay BAYRAMOĞLU
k.bayramoglu.b@gmail.com |
September 2, 2017, 22:03 |
Sir, I am facing the same problem of negative cell volume.
#16 | |
Samm
Sir, my email id is saumyaranjan.nayak93@gmail.com |
Dynamic mesh & Negative volume in 3D | mahzironrazak | FLUENT | 97 | December 28, 2020 22:09 |
Negative Volume during Mesh Motion Analysis | giov_ingr | FLUENT | 2 | December 13, 2013 06:09 |
negative cell volume during dynamic meshing | Tamjid | FLUENT | 1 | September 5, 2011 02:33 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
