March 15, 2012, 22:47 |
Eulerian Model - properties
Kim Donghee
Rep Power: 17 |
Dear all
I have a question about properties in multiphase flow, Eulerian model. Manual described that Momentum and continuity equations are solved for each phase. What does it mean exactly? If primary and secondary phase exist in same cell, how calculate properties in fluent? I think since equations are solved for each phase, does not affect each other. if primary phase is 0.8, i.e, secondary phase is 0.2, and density of each phase are 100 and 1000, density is 0.8*100 + 0.2*1000=280 in cell? or does not affect? Just use 100 for solving the primary phase and use 1000 for solving secondary phase? I wish listen your comments Thank you all Bests |
March 16, 2012, 01:34 |
chenxizhong
Rep Power: 14 |
The Eulerian model is Momentum and continuity equations are solved for each phase. That means if you have two phase such as gas-solid, you will sovle two eqution for gas(use the denstiy of gas ), and two eqution for solid (use density of solid ).
Other model named Mixture model is available in fluent ,too. In Mixture if you have two phase, you just solve two eqution, that is mixture of gas and solid used density 280 you mentioned. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Eulerian Multifase model with species transport | Valeria | FLUENT | 0 | July 19, 2008 16:48 |
Eulerian porous model | kevin | FLUENT | 0 | December 3, 2006 10:45 |
the interface bc in Eulerian Model | lily | FLUENT | 0 | July 28, 2005 02:37 |
DPM + Eulerian Model | Shane | FLUENT | 2 | July 14, 2004 08:26 |
