April 15, 2012, 09:15 |
Mass flow rate.
AHMAD
When i make a periodic boundary condition, fluent calculates inlet area based on z=1m by default, is there any way to change this z, or i just have to continue my mass flow rate calculation based on this inlet area. Thank you. Last edited by A7A; April 15, 2012 at 17:28. |
April 16, 2012, 12:17 |
AHMAD
Any one have any suggestion about this problem, could i change this z or not? Thank you. |
April 16, 2012, 12:21 |
Rep Power: 15 |
Do you want to monitor the mass flow rate?
April 16, 2012, 12:44 |
AHMAD
I just want to make the inlet area in fluent equal to the real inlet area that i want it , and so not going through addittional calculation to adapt to fluent inlet area. Thank you for your reply. |
Particle Injection Mass Flow Rate and Position | leonozx | FLUENT | 3 | March 9, 2018 09:58 |
CFX turbo - Mass flow rate | Vashishth Patel | CFX | 7 | April 3, 2014 20:33 |
Mass flow rate at the outlet | tejasvikrishna | FLUENT | 2 | May 25, 2013 02:42 |
negative global mass flow rate | Gimli | FLUENT | 0 | April 21, 2006 07:17 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
