Can I scale up from 1 to 2 nodes with mixed CPU? |
April 12, 2014, 22:59 |
pong
I want to see how scaling up from 1 to 2 nodes improves the calculation speed on CFX. I already have 2500K/Z68 system. Is it ok to buy the FX-3850 system to connect to my old one with GigE?
April 14, 2014, 11:15 |
Rep Power: 18 |
You could certainly do that, but I'd probably just get another 2500k instead, especially if you're paying a per-CPU license. That AMD chip isn't really any faster than the i5, but it uses a lot more power and twice as many licenses. Plus I always prefer to keep things homogeneous, even if it isn't explicitly required.
April 14, 2014, 15:50 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
According to cpubenchmark.net, the Intel i5-4570 is a bit faster than the Intel i5-2500K and costs roughly the same as an AMD FX-8530. Better still, the i5-4570 consumes less electricity than either one of the other two.
As for CPU performance index, the FX-8350 (index of 9047) has roughly 2000 performance points (whatever that is ) more than the i5-4570 (index of 7080), but this means using the 8 cores. As for using a Gigabit Ethernet, it's a bit unbalanced, since it'll be 8 vs 4 cores, unless you only use 4 cores on the AMD... but for that, probably best to go with the i5-4570. |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
Running damBreak with OpenFOAM 15 and Open MPI on mixed up CPU Systems | engys | OpenFOAM Running, Solving & CFD | 8 | November 26, 2008 04:57 |
OpenFOAM 13 Intel quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 13 | February 5, 2008 05:26 |
