January 17, 2017, 04:26 |
HPC upgrade - # of cores or GHz?
Chris
Rep Power: 9 |
Hi everyone,
I was asking myself if the number of cores or a higher frequency would be a better choice for upgrating the HPC cluster at my workplace. In detail, I'm currently running 4 nodes, each with 2x Xeon E5-2630 v2 and 64 Gb memory. I want to add 2 more nodes and need to decide wether to use 2x 14-Core E5-2680V4 @ 2.4GHz with 64 or 128 Gb memory - or 2x 8-Core E5-2667V4 @ 3.2 GHz with 64 or 128 Gb memory. The software I'm using is Ansys CFX - Fluent. Does anyone can give me an advice which would be a better choice, independent from any price related issues? Thanks Chris |
January 17, 2017, 08:39 |
Alex
Rep Power: 46 |
Without considering the hardware prices these are the best dual-socket processors for CFD when you have significant license costs.
E5-2687W v4 - 12 cores - 30MB Cache - 3.2 GHz all core turbo E5-2667 v4 - 8 cores - 25MB Cache - 3.5 GHz all core turbo E5-2643 v4 - 6 cores - 20MB Cache - 3.6 GHz all core turbo E5-2637 v4 - 4 cores - 15MB Cache - 3.6 GHz all core turbo If you have more than 16 parallel licenses, the E5-2687W v4 is your best option. To answer you question in a more general sense: Frequency is usually more important than the number of cores since higher number of cores increase the parallelization overhead. So going for a higher number of significantly slower cores is usually not a good idea for CFD. Additionally, maximum memory bandwidth is the same for all these processors so you are more likely to cause a bottleneck here with high core counts. |
January 17, 2017, 08:55 |
Chris
Rep Power: 9 |
Hi Alex,
thank you for your answer. So I probably go with the 8 core CPU's. I'm going to contact Ansys support though and see what they say just to get another point of view. Thank you! |
January 17, 2017, 09:51 |
Alex
Rep Power: 46 |
Feel free to sum up their answer here. I am pretty sure what it will be, but as you suggest it is always good to have a second opinion.
January 31, 2017, 05:42 |
Chris
Rep Power: 9 |
Hi again and sorry for the late reply.
So the Ansys customer service didn't give a specific answer to my problem about the number of cores vs. frequency question... what they did say was, that CFX scales well with a number of Xeon E5 26xx processors which is not very helpful. But they also said, that CFX was generally invented for parallelization so I should rather go with more cores if the jobs get big and if I have sufficient memory ( about 4 Gb / core ) and licences. From a number of configurations, the (2x nodes) 2x 14-Core Broadwell E5-2690v4 Xeon with 128 Gb memory option was the one Ansys advised and that's probably what I'm going to choose. Please everybody, do not see this as a recommendation of what to buy! It's what I am choosing for my specific task and with the capabilities I have. Best regards Chris |
Some ANSYS Benchmarks: 3 node i7 vs Dual and Quad Xeon | evcelica | Hardware | 14 | December 15, 2016 06:57 |
HPC server (AMD) to 40 million cells - How cores do I need? Where I can buy it? | Ferdinand | Hardware | 13 | March 7, 2016 11:04 |
Which is better for CFD 4 core i7-2600 or AMD 8 core FX-8150? | GregShaffer | Hardware | 3 | May 7, 2015 13:26 |
16 cores X5550, 48Gb RAM HPC purchase | ACmate | Hardware | 6 | May 28, 2010 01:00 |
P4 1.5 or Dual P3 800EB on Gibabyte board | Danial | FLUENT | 4 | September 12, 2001 11:44 |
