Home > Forums > General Forums > Hardware
Verification/Suggestion of Hardware Setup for CFD with OpenFOAM
Old   September 21, 2020, 14:55
Default Verification/Suggestion of Hardware Setup for CFD with OpenFOAM
Dominik
taylor85 is on a distinguished road
Hi there,
i would like to build up a new home pc for CFD purposes. My budget is between 2.000 - 2.500 EUR.
I already have built up a hardware setup consisting of the following hardware:
Mainboard Asus PRIME X299-A, Intel X299
Processor Intel Core i9 10920X 12x 3.5GHz
Power Supply Seasonic Core GC-650 Gold, 650 Watt
Cooler be quiet! Dark Rock Pro 4
RAM 32GB DDR4-RAM PC-3600 (4x 8GB)
overclocking DDR4-RAM, G.Skill Ripjaws V, 4x 8GB
Graphics Nvidia GeForce GTX1660 Ti 6GB, Palit StormX OC
6144MB GDDR6-RAM
Hard Disk 1 NVME M.2 SSD 500GB Kingston A2000
Hard Disk 2
SSD SSD 500GB Samsung 860 Evo MZ-76E500B
Concerning the RAM, I have a question: Is there anything hardware specific at the RAM itself, so that it is suitable for Quad Channel Mode? I am asking because the webshop states that the RAM is "Dual Channel". But I thought that the quad channel mode depends solely on the memory controller of the mainboard and the number of modules (4 or 8)?
I would be very happy about any hints whether the setup sounds reasonable for CFD calculations. Furthermore I would appreciate any suggestions if one could build a different system which would be more suitable still considering the budget.
Thank you very much in advance for your replies.
Cheers
Dominik
taylor85 is offline   Reply With Quote
Old   September 22, 2020, 14:31
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
You are right. 4 identical memory modules can be used in quad-channel mode. No matter if they were sold as four single DIMMs, or came together in a box. A pack of 2 DIMMs advertised as "dual-channel RAM" is just the seller trying to cater to the average consumer, who does not care about any of the details, and needs to be reassured that this will get him this "dual-channel" that he read about.
Theoretically, you could run into trouble with 4 DIMMs that came in 2 different packages, despite buying the same brand and model. Some memory manufacturers change the ICs in their memory modules without notice. But the chances of that happening when you buy two packs from one shop at the same time are pretty slim. And the chances of that leading to incompatibilities without extreme overclocking is also pretty small.
https://geizhals.de/?cat=WL-1604742
91€ over budget, but absolutely worth it. Considering you get 2TB of NVMe storage, a really fast 16-core CPU with 64GB of RAM, and the option to double performance later on by just dropping in a second CPU and RAM.
flotus1 is offline   Reply With Quote
Old   September 22, 2020, 15:08
Simbelmynė's Avatar
Simbelmynė is on a distinguished road
You can shave off 150 Euros by changing the GPU to an RX 570 (or rather a 580 since they are only 10 Euros more today).
You can also opt for a 9800X and save another 400 Euros for almost the same performance in CFD.
So for 550 Euros less you would essentially have the same performance.
The Epyc suggestion will be a much better CFD option though, especially in the long run (I assume that you have unlimited parallel licenses, if you do not then the Epyc might be worse).
Simbelmynė is offline   Reply With Quote
Old   September 24, 2020, 13:57
Dominik
Thank you both for the quick replies!
@flotus: The Epyc configuration seems to be a good choice. But I have two more questions: I found that the mainboard you propose supports only 2666 MHz RAM and you recommended 3200 MHz RAM. Is there a reason that you did not choose the "NT model" of that mainboard:
https://geizhals.de/supermicro-h11ds...loc=at&hloc=de
Or is it not worth the higher price?
Furthermore I was wondering why the PCIe ->M.2 Converter is needed, because the mainboard does have a M.2 slot? Does it support higher read/write speeds?
Thank you for your reply!
Cheers
Dominik
Old   September 24, 2020, 14:06
flotus1's Avatar
Alex
I linked you the revision 2 of this board, which does in fact support Epyc Rome CPUs, and memory transfer rates up to 3200MT/s out of the box. The info on this site is manually curated, and not always 100% accurate. So be careful to get a board labeled as "R2.0".
The only difference between H11DSi and H11DSi-NT: the latter has built-in 10Gigabit Ethernet. Entirely up to you whether you need that.
That m.2 to PCIe adapter card will help you get the most out of a fast NVMe SSD. The onboard m.2 slot on any Supermicro H11DSi is only connected via 2 PCIe 3.0 lanes, limiting sequential throughput on this kind of SSD. They need 4 lanes for maximum throughput.
Old   September 24, 2020, 14:42
Dominik
Thanks agasin for your quick reply. Just another question: Is the ECC RAM necessary. Or would'n it be a good choice to to get a faster non ECC RAM like that one (for nearly the same price):
https://geizhals.de/g-skill-ripjaws-...loc=at&hloc=de
Cheers
Dominik
Old   September 24, 2020, 15:24
flotus1's Avatar
Alex
This is not about ECC, that's just a nice bonus. Epyc CPUs and boards are incompatible with UDIMM, you need RDIMM aka registered memory. There are very few RDIMMs without ECC, But they are not cheaper, and have just the same loose timings as reg ECC.
Additionally, there is no memory overclocking on this platform. Epyc CPUs have a hard cap at their rated memory transfer rate. It is technically possible to adjust memory timings with an unlocked bios on H11DSi motherboards. But let's leave such extreme measures out of the equation for now
If you want even higher memory performance, spending more money on 16GB modules with 2 ranks would be an easier route. The price/performance ratio of this measure is pretty bad though.
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 19:20
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
Hardware for OpenFOAM Cluster Edge99 Hardware 1 March 6, 2013 14:09
State of OpenFOAM for hardware support Sonthun OpenFOAM 1 October 23, 2010 01:09
